Another take on the dubbing block
Postby Tom Smithwick » Sun Mar 08, 2015 2:45 pm
I always used the dubbing loop method if I wanted a shaggy fur body. No block or anything, just inserting the fur noodle or cut fur into the waxed loop by hand. Since joining this site, I have seen the advantages of the block for mixing furs, etc. I determined to see if I could come up with a vise mounted alternative, so that I could spin the bodies as I tied the fly. No reason, just a preference. The first attempt was OK, but the smooth top of the block proved a bit squirrely to work with. I ran across the idea of using an iron on fabric patch, I think it was Ray's idea. That helped a lot. Here's what I ended up with. I'm not tying a fly here, just using some thread and fur that I hope shows up. Oh, and Happy St Patricks day.
The thread laid in the groove and covered with fur
Thread laid over the fur with a hook in place to spin the thread. Bobbin hanging over the hook. A fairly heavy bobbin is a good idea.
Same step from the back of the vise
Thread twisted, block swung out of the way, ready to wrap the body.
Tom Smithwick
Re: Another take on the dubbing block
Postby Tom Smithwick » Sun Mar 08, 2015 3:14 pm
A look at the bottom of the block. It helps to have a metal lathe, but the same could be done with a hardwood block. I thought I might need to drill through the bushing and tap it for a set screw, but on my vise the block bumps into the adjustment screw on the jaws, and stays put.
The flies were tied using the block. The Isonichia from a beaver fur chenille which was then trimmed to shape. The Hendrickson flymph from blended reddish brown and silver mink fur.
Tom Smithwick
Postby Old Hat » Sun Mar 08, 2015 3:29 pm
Nicely accomplished Tom. I have been using a Norvise for a couple years now to make prespun dubbing ropes with a similar block set up. I haven't quite figured out the best method while on the hook yet. You have given me some ideas.
Postby Smuggler » Sun Mar 08, 2015 5:40 pm
Wow that's awesome.
Smuggler
Postby tie2fish » Sun Mar 08, 2015 6:00 pm
Devilishly clever, Tom. A toolmaker's mind at work,
Postby DUBBN » Sun Mar 08, 2015 6:04 pm
Great looking patterns sir! I like the vise too.
Postby gingerdun » Sun Mar 08, 2015 6:25 pm
Hi Tom,
Great to see your inventiveness. Very cool.
gingerdun
Postby DOUGSDEN » Sun Mar 08, 2015 7:08 pm
Tom,
A really great idea esp. the groove cut into the block! That would change the dynamics of how the fur radiates from the two layers of spun thread. Wow, you really got us thinking.....
Intrigued D.
Postby William Anderson » Sun Mar 08, 2015 9:44 pm
Tom, it's always cool to see the variations on the theme. You'll have a bit more control over the trickier dubbing than a typical dropped loop, and keep the extra stand of thread as part of the body that you lose with the split thread. I watched Carl work with his nor vise platform in Roscoe and it really had potential. I hope you fool with this to discover its advantages.
Postby letumgo » Fri Mar 13, 2015 10:35 pm
Tom - brilliant version of the dubbing block. I like the fact that your hands are left free to manipulate the dubbing and the block can be positioned level with the hook shank. I need to give this a try. This variation of the dubbing block looks quite effective. Very cool.
Henry David Thoreau
Next
Who is online
Users browsing this forum: No registered users and 2 guests
cron
