Kræ 2
Kræ 2
Postby ScottP » Thu Jan 25, 2018 1:19 pm
A Danish seatrout fly; this could also be used as a wet in freshwater. Original had grizzly marabou throat but I preferred the hackle; use what you will.
hook - Mustad 9671 #8
thread - Danville 6/0 black
rib - small wire silver
tail - grizzly marabou
body - tinsel silver
hackle - hen grizzly
wing - calftail white
topping - peacock swords
Scott
ScottP
Re: Kræ 2
Postby daringduffer » Thu Jan 25, 2018 3:14 pm
Very nice and well tied as could be expected.
Re: Kræ 2
Postby letumgo » Thu Jan 25, 2018 8:43 pm
Perfection...
How did you wrangle the sword fibers like that? What’s your secret?
Really impressive!
Henry David Thoreau
Re: Kræ 2
Postby ScottP » Thu Jan 25, 2018 9:38 pm
letumgo wrote:How did you wrangle the sword fibers like that? What’s your secret?
Thanks for the kind words. I trimmed a section of quill with the fibers still attached, layed them on top of the wing with the curve pointing the way I wanted and tied them in (only took 2 tries!). If they don't lay right, you can unwrap and try again; since they're still on the quill, it's easy to stroke them back into alignment (once they're off the quill it's almost impossible to get them to behave).
After the fact I found a Davie McPhail video that shows it better than I can explain (right around the 6:00 mark)
https://m.youtube.com/watch?v=CjsRaklkuMw
Scott
ScottP
Re: Kræ 2
Postby letumgo » Fri Jan 26, 2018 6:21 am
Thanks Scott. I’ve used this technique, but still ended up with a couple “strays”. Guess I just gotta practice. :D
Henry David Thoreau
Re: Kræ 2
Postby ScottP » Fri Jan 26, 2018 7:51 am
letumgo wrote:I’ve used this technique, but still ended up with a couple “strays”. Guess I just gotta practice. :D
The 5 coats of Krylon high gloss help, too.
Scott
ScottP
Re: Kræ 2
Postby letumgo » Fri Jan 26, 2018 12:45 pm
Your attention to detail is what makes the final fly look so nice. A "frame worthy" fishing fly.
Henry David Thoreau
Return to Fly Dressings - Winged Wet Flies
Who is online
cron
