Dyeing dubbing
Re: Dyeing dubbing
Post by Ruard » Tue Apr 07, 2009 3:49 pm
Hi Mike,
If I click on your pictures then I get also a lot of reclames. Perhaps you can try www.tinypics.com If you copy the link with the [img].................[/img] on both sites I don't see any reclame any more.
Thank you for all the information you put on this forum, I look forward to the polyline.
Re: Dyeing dubbing
Post by Ruard » Wed Apr 08, 2009 3:30 pm
Mike wrote:Hmmm.....you shouldn't need to click on them at all, they should just show up in the post.
Hi Mike, You are right, but when I will see them bigger I dubbelclick on them to enlarge, like the other foto's.
Re: Dyeing dubbing
Post by Roadkill » Tue Jun 09, 2009 11:47 am
Mike.
Nice discussion on dubbing but I differ on the only sensible method unless a divorce is the object. :D
I did a lot of loose dubbing dying since that is the only way my wife's lop eared rabbit would shed it for my tying and I use Rit since it is easy to find down at a local store instead of better dyes that can only be found hundreds of miles from where I live. Here is a simple drying rack from my shop. I like plain old rabbit as as a binder with mixes of synthetic yarns.
Either dyed or wet mixed(color blends) in a blender poured on the screen squares make a nice dubbing felt that I put in press lock sandwich bags for storage. A permanent marker added the formula used for that batch on each bag. It dried nicely overnight on top of my heating boiler in the Winter.
