New flymph tier
Re: New flymph tier
Nice job!
Re: New flymph tier
NeoDoc, Howdy;
Now ya be tyin' !
Now ya be tyin' !
Re: New flymph tier
Nice flies they both have fish catching elements that will work-dubbing, flash, and fluttering hackle!
Re: New flymph tier
Feeling better about this one - Hare's Ear - put in thread bump to elevate the tail
- FullSizeRender-48.jpg (105.06 KiB) Viewed 8135 times
Re: New flymph tier
The rate of evolution is amazing to me.
Re: New flymph tier
Same here. I'm sorry I'm just chiming in here. Thanks so much for posting these early efforts. It will be fun over the years (or days in your case) to see the progression towards what you're imagining. This will work like a charm. I'd fish that all day.tie2fish wrote:The rate of evolution is amazing to me.
A couple thoughts, if you care for a suggestion. What size hook are you tying on? I know materials work best in their designed purpose, but starting on a big #12 will help you find the proportions and desired effect which will very quickly translate to smaller sizes. This rib still seems large for this fly, but not an issue. Some softies are tied with tinsel only and bling can be a remarkable element in the right conditions. In my opinion the hackle length is great, the tail length dead on and the bump is a very nice touch. Nice work all around and a pleasure to see this. Thanks again.
Re: New flymph tier
This was tied on a #14 Orvis dry. Does anyone use XS ultra wire for ribbing? Thanks for the encouragement.
Re: New flymph tier
Hey Doc, I'll post a few options just for your consideration. This is a fine wire, larger than xsmall uni-wire but smaller than small uni-wire.
http://www.flymphforum.com/viewtopic.php?f=6&t=6761
This to me looks like x-small wire rib. Bill can confirm or deny.
http://www.flymphforum.com/viewtopic.php?f=6&t=6582
Check this thread. Eric used a very fine wire rib, and if you scroll down you'll see I've used a fine rib on some and a small uni-wire on a few. The difference should be obvious. Sometimes for added bling I'll use a slightly larger wire like a few of these.
http://www.flymphforum.com/viewtopic.php?f=6&t=6571
This might be helpful. The top fly is ribbed with very fine silver wire. The second has no rib at all, and the third is a small tinsel rib. The width of tinsel can be subjective. Sometimes you just have to try a few.
http://www.flymphforum.com/viewtopic.php?f=6&t=6526
Re: New flymph tier
FWIW, JL more often than not used "oversized" tinsel.
Re: New flymph tier
As did Pete Hidy, here are some of our previous ribbing discussions...tie2fish wrote:FWIW, JL more often than not used "oversized" tinsel.
http://www.flymphforum.com/viewtopic.ph ... own+flymph
http://www.flymphforum.com/viewtopic.ph ... ide+tinsel
