Saber Hooks?
Re: Saber Hooks?
Post by Old Hat » Sat Jun 22, 2019 5:53 pm
No luck, sorry John.
Trifly
Re: Saber Hooks?
Post by Trifly » Sat Jun 22, 2019 6:03 pm
ForumGhillie wrote: Sat Jun 22, 2019 3:54 pm
Old Hat wrote: Sat Jun 22, 2019 1:24 pm
SenecaLaker wrote: Sat Jun 22, 2019 7:25 am
Carl, I've never tied on those hooks, i'd love to have a few if you wouldnt mind.
Dave
Sure, I'll get some out to you.
Carl, If you have any Dai-Riki #270 size #10. I use them on some of my soft hackle patterns. Will pay you for them.
John
Per
100
Trifly
Re: Saber Hooks?
Post by Trifly » Sat Jun 22, 2019 6:05 pm
Per 100
Wholesale Fly Company
Re: Saber Hooks?
Post by Theroe » Mon Jun 24, 2019 2:33 pm
RickA wrote: Thu Jun 20, 2019 11:13 am
Trifly wrote: Wed Jun 19, 2019 7:00 am I am in the Wholesale Fly Company camp as well. I have started replacing my now discontinued Dai-Riki stock with them.
Wait... are you saying Dai-Riki is discontinuing their line of hooks, phasing out certain model numbers,
or you just like Wholesale Fly better?
They look to be a very very close match -
Re: Saber Hooks?
Post by Theroe » Mon Jun 24, 2019 2:36 pm
daringduffer wrote: Wed Jun 19, 2019 5:33 am
Bazzer69 wrote: Tue Jun 18, 2019 10:13 pm I like some of the older hooks as well, but I have had problems with them breaking when I try to pinch the barb down. Those are just too brittle. 😎
B
You have to 'roll' those brittle barbs down by 'squeezing' them from the tip towards the bend of the hook in order to avoid breaking them. The easiest way to do this is to use pliers with bent jaws. The difficult part is to find such pliers that are fine enough. You probably need to modify a pair.
When you grip the hook with the pliers the lower jaw is supposed to be still and the upper jaw should move towards the hook bend, squeeezing the barb down in the process.
Clear as mud??
Hemostats, or a jewelers file work fine.....
Trifly
Re: Saber Hooks?
Post by Trifly » Mon Jun 24, 2019 4:07 pm
You folk put way too much thought in to smashing barbs. I promise Mustad is not as sensitive as you make them out to be.
Theroe wrote: Mon Jun 24, 2019 2:36 pm
B
Clear as mud??
Bazzer69
Re: Saber Hooks?
Post by Bazzer69 » Mon Jun 24, 2019 7:05 pm
dd and others, I actually solved the problem by using a Dremel tool and grinding the barbs off.
B
But not much good at either
Trifly
Re: Saber Hooks?
Post by Trifly » Mon Jun 24, 2019 8:16 pm
If I ever have to take a dremel to a hook, I will know right then I have been cheated. So weird
Re: Saber Hooks?
Post by Roadkill » Tue Jun 25, 2019 9:21 am
I use smooth jaw pliers and insert the hook into the front of the jaws not the side. The force closes down first on the barb applying pressure toward the bend. Jewelry making pliers from craft stores are my favorite. ;)
Bazzer69
Re: Saber Hooks?
Post by Bazzer69 » Tue Jun 25, 2019 4:50 pm
Trifly wrote: Mon Jun 24, 2019 8:16 pm If I ever have to take a dremel to a hook, I will know right then I have been cheated. So weird
With the very old Hardy hooks that I have there is no way pinching the barbs down works, a broken hook every time. I’m not the only one who uses a Dremel to remove the barbs. It’s a fine tool in both senses
