Hello,
Just wondering if anyone knows of a good midge sized bobbin holder that will work with the small sewing machine bobbins? I would think that one which works with Pearsall would work. I found some old silks on these that I want to try. I could respool, but I’d rather not. Many make “midge” bobbin holders, but it’s hard to tell from the ads if they are referring to tube size for close in work or if they actually work with the sewing machine spools. While I have several Matarelli holders, unfortunately none are the midge size.
Craig
Midge Bobbin Holder?
Re: Midge Bobbin Holder?
I have 3 of the old Wasatch bobbins that hold small spools but they are no longer available.
It's a shame because they made some nice tools.
I did find some bobbins on ebay that hold 10mm spools, sewing machine size, that should work.
They have ceramic tips and wood handles like the Wasatch.
https://www.ebay.com/itm/371613570387
A set of 3 goes for $12 so you really can't go wrong
Good luck and let us know if they work for you.
You could cut a small piece of tubing and put it through the small spool. Then put tubing in the bobbin
- SenecaLaker
here is my solution from a few years ago. I cut a few rounds from a solid surface material from a bathroom remodel.
I recessed the center to hold the bobbin. it works well.
- Capture.PNG (709.71 KiB) Viewed 16076 times
- 3.PNG (941.04 KiB) Viewed 16076 times
- Capture2.PNG (639.78 KiB) Viewed 16076 times
- Capture3.PNG (704.37 KiB) Viewed 16076 times
