by DUBBN » Thu Nov 26, 2020 6:28 pm
Size 20 Wholesale Fly Company, model 5
Thread, Veevus Gray 16/0
Thorax, Muskrat
Collar, Brown or Dark Dun hen hackle
Looks like Winter to me. These little morsals will produce all the way to Mothers Day
DUBBN on Thu Nov 26, 2020 7:07 pm, edited 1 time in total.
by Roadkill » Thu Nov 26, 2020 6:56 pm
Great looking flies!!
How much longer is the #5 compared to their standard #7?
by DUBBN » Thu Nov 26, 2020 7:02 pm
Roadkill wrote: Thu Nov 26, 2020 6:56 pm
It would probably compare to a size 18 Model 7
by DUBBN » Sat Nov 28, 2020 8:42 pm
by Roadkill » Sat Nov 28, 2020 9:36 pm
Really nice, what is the rib? Is that resin or head cement coating the body under the rib?
by DUBBN » Sat Nov 28, 2020 10:29 pm
Roadkill wrote: Sat Nov 28, 2020 9:36 pm
The rib is a single pheasant tail fiber.
I apply thin UV resin (Loon Flow) to the body of the pattern, rib with the PT fiber, then set the resin with my light. The fragile PT fiber is then bonded to the fly.
by ronr » Tue Dec 01, 2020 9:00 am
DUBBN's flies continue to impress and inspire me. It didn't take long for me to steal his idea of imbedding a pheasant fiber in UV as a rib. So I turned his midge larva into a soft hackle. Same body, some Vicuna alpaca dubbing for thorax and a dun hen hackle.
- fullsizeoutput_7c4.jpeg (248.1 KiB) Viewed 3949 times
by Roadkill » Tue Dec 01, 2020 10:41 am
Beautiful fly Ron!! The rib and the dubbing complement each other nicely!
by DUBBN » Tue Dec 01, 2020 11:10 am
ronr wrote: Tue Dec 01, 2020 9:00 am
DUBBN's flies continue to impress and inspire me. It didn't take long for me to steal his idea of imbedding a pheasant fiber in UV as a rib. So I turned his midge larva into a soft hackle. Same body, some Vicuna alpaca dubbing for thorax and a dun hen hackle.fullsizeoutput_7c4.jpeg
Good looking pattern!!!
Should you end up tying more , here is a little hack I learned....
Tie in two PT fibers. Just in case you break the first one while wrapping it.
I tied a half dozen in Red. With Red PT.
My quarantine ends tomorrow, and I may brave the temps and try them out.
by letumgo » Tue Dec 01, 2020 12:23 pm
Good luck, if you get out fishing today Wayne.
You guys are posting great looking flies. Keep cranking them out. Very inspiring ideas.
