Funny thing
Funny thing
Post by narcodog » Fri Oct 26, 2012 10:18 am
Yesterday was a tuff fishin day, we were throwin everything in our box. Any after fishin a s/h with no luck in a run where there always fish I decided to change flies. Instead of just pulling the line in I reeled it. Now I was bringing it as fast as I could reel and then bam, a brown was on. I can't ever remember catching a trout on a fly that was being retrieved like a spinner.
Re: Funny thing
Post by letumgo » Fri Oct 26, 2012 11:04 am
I can remember loosing a couple nice steelhead that way. They will sometimes hit a fast moving fly like a ton of bricks. Unfortunately they will often break off, since the line is tight and I often have the rod tip down close to the water (i.e. - no chance to absorb the strike).
Re: Funny thing
Post by redietz » Fri Oct 26, 2012 6:43 pm
That's how I discovered that a Renegade works when stripped in quickly.
Re: Funny thing
Post by William Anderson » Fri Oct 26, 2012 7:48 pm
Bob, I've been obsessed lately with understanding presentations for flymphs and spiders. Sometimes it's hard to develop a sound theory when they are taken in so many ways for so many reasons. What were the water conditions/stream section like and what kind of tippet were you using?
Re: Funny thing
Post by narcodog » Fri Oct 26, 2012 7:55 pm
William, the water is a tail water about 10 miles below the outlet. Flow was low, crystal clear with plenty of leaves when the wind puffed. I was using a 5x tippet on a 5 ft furled leader. The run was over a shoal with a hole about 3 ft deep. Between two little runs was a little calm. So when I was reeling in the fly came through some of the run into the flat. That's when he hit, smacked the heck out of it. I had missed one earlier in the same area on a dead drift. I also had one flash on it also but no take.
Re: Funny thing
Post by CreationBear » Fri Oct 26, 2012 8:19 pm
Reel? :lol:
One of the things that intrigues me about Tenkara (and will no doubt give William something else to obsess about this Spring) is that it makes the classic upstream dead-drift/downstream "lift" just one presentation option out of many. In Narco's case, I'm guessing that the trout were taking caddis emergers--this time of year, especially, I'm always careful to fish the entire drift, even if I'm fishing dries--the biggest Smokies rainbow I've brought to had so far took a Tennessee Wulff pulled under and "pulsed" back. I also suspect that we fishermen get too obsessed with aquatic insects and ignore other columns on the menu--who's to say that a even a smallish softhackle moving at "flank-speed" might not resemble a small crayfish or young-of-year fry?
Re: Funny thing
Post by narcodog » Fri Oct 26, 2012 8:58 pm
Reel! :lol:
I had the other but decided to use a "new" cane rod. I bet I had drifted, stripped back six different flies through that run over a 30 min period.
fflutterffly
Re: Funny thing
Post by fflutterffly » Fri Oct 26, 2012 10:13 pm
Bob could catch a fish even if Bob were fast a sleep in his car with the rod in the truck. this guy is a blast to fish with. Love ya bob. Sorry we couldn't make it up to fish in Oct. but Karen is ill... again.
Re: Funny thing
Post by redietz » Fri Oct 26, 2012 11:02 pm
William Anderson wrote:Bob, I've been obsessed lately with understanding presentations for flymphs and spiders. Sometimes it's hard to develop a sound theory when they are taken in so many ways for so many reasons. What were the water conditions/stream section like and what kind of tippet were you using?
I was fishing the Gunpowder above Falls Road in low water conditions summer a year ago. There was a pod of rising trout about 15 feet across from me, and I was determined to prove my theory that any trout rising in the GP can be taken on a size 16 Renegade and 5x tippet (as long as it's long enough). I tried floating presentations (both upstream and down), sunken presentations (both upstream and down, with and without weight), and on the swing. I couldn't move a fish, but didn't put them down, either. After almost an hour, I gave up and just started reeling in. The fly was smacked immediately by the largest fish in the pod. After that, I fished it for the next half hour with a good hard strip retrieve and took about 5 more fish from the same spot.
fflutterffly
Re: Funny thing
Post by fflutterffly » Sat Oct 27, 2012 7:58 am
Sorry guys I made a post to my friend NorcalBob instead of Narcodog. sometimes a gal is just ditzy.
