Here's my tying sequence. If anybody has suggestions for improvement, please speak up.
Lance
- 1. Start the thread near the bend. (Maybe I should start at eye to cover the entire shank with waxed thread to form a secure base.)
2. Tie in 3 pheasant tail barbs above the bend
3. Tie in Rib #1, the narrow gold tinsel
4. Tie in Rib #2, sparsely-dubbed spun body (Clark block), and secure it and the tinsel in a clip out of the way
5. Wind four or five wraps of thread away from the bend and then tie in the 4-strand wool
6. Trim barbs off left side of hackle
7. Wrap thread to mid-shank and tie in hackle by the tip, pointing to eye. (In the photo, I tied it in too far down the shank)
8. Continue wrapping thread to head
9. Wrap the wool body, manipulating and reversing direction to build taper, and tie off at eye
10. Wrap Rib #1, the tinsel, with a few tight wraps over the tail and then continue over the yarn in a widely-spaced spiral.
11. Wrap Rib #2, the dubbed rope, very close to the tinsel, and tie off at head
12. Wrap hackle in space between the ribs and tie off at head.
13. Build thread head to continue the taper to a point.
