Wax Question
Wax Question
I have some of Jim's old wax beads. Some of you may remember them. They were about the size of tic-tac. Hard as a rock but softened nicely with a little work. I have a bag of shattered pieces.
Is there a way to soften these as a bunch and reform them into the small beads again?
I like them in the small beads because I hand them out to people who show an interest at the shows when I'm tying.
Can I heat them up in some water as bunch?
zen leecher
Re: Wax Question
This might not work on your wax but the 721f wax I had that hardened softened up after I gave it some time in the microwave. It stayed easier to soften afterwards.
PS: pins came last week.
Re: Wax Question
I've never used any of Jim's wax but what I would do is soften it in your hand and pull and stretch it like taffy. If it is still difficult to work you could add a little oil or fat; very little.
Re: Wax Question
Old/New Hat, Howdy;
put them on a sheet of waxed paper and set them in front of a window
that that good ol' Florida sunshine is shining through.
Should only take a few minutes.
- Ron Eagle Elk
Re: Wax Question
Carl, I reconstituted some back into beads by putting the shards in hot water (hot from the faucet, not the stove) for a few minutes. Softened right up and could be remolded into beads. I keep the beads in a small jar of water now.
Re: Wax Question
When I read Hank's email, I thought he was going to say use wax paper and an iron...
Although he didn't, I suspect that might be an idea: a cool iron and parchment paper (probably better for the iron than the wax paper).
Just a thought.
Just a thought.
Re: Wax Question
Surely wax hardens over time due to the VOC’s. Whilst you can soften it with heat it is unlikely to ever be the same. Wax is inexpensive, Bill Bailey’s is a excellent wax for flymphs. Storing wax in water is a good idea and will prolong the life of new wax.
There has been many threads about the “best” wax. I have ended up buying several. It’s actually fun to find the best ones that suit you.
B
B
But not much good at either
