skunkaroo
by skunkaroo » Sat Nov 21, 2009 1:25 pm
Crunchy Damsel
- Hook: #14 Daiichi 1720
- Thread: Ginger 10/0
- Hackle: Furnace Hen
- Tail: Ginger marabou
- Rib: Copper wire
- Body: 6-8 Twisted ginger marabou fibres
This riffs on the cruncher and the marabou damsel. It's proved to be a deadly stillwater pattern. I usually tie it on a Mustad 9672, but I thought I'd try it on a hook with a longer point. I apologize for the "fishing quality" finish.
Hans Weilenmann
by Hans Weilenmann » Sat Nov 21, 2009 2:33 pm
Nice one Aaron. Very yummy
skunkaroo
by skunkaroo » Mon Nov 23, 2009 1:46 pm
Thanks for the kind words. As a show fly this leaves a lot to be desired. I haven't yet figured out an acceptable way to transition neatly between the body and hackle. A spot of ginger dubbing would probably do the trick.
Anyway. As a stillwater fishing fly this has been a great and consistent producer. I'm thinking of adapting it for a few stream hatches this coming season. I'll let you know the results.
Hans Weilenmann
by Hans Weilenmann » Mon Nov 23, 2009 2:04 pm
Aaron,
Not sure what you have tried yet, but with the hackle tied in first (and wrapped last), the transition really should end up seamless, no?
skunkaroo
by skunkaroo » Mon Nov 23, 2009 2:27 pm
Not entirely, Hans. I do tie these with the hackle forward, but given the relative thickness of the twisted marabou and the corresponding "thick" tie-off point I'm having trouble getting a nice seamless transition. I've tied this "Stewart style" before, and while it works, it's not ascetically pleasing. Any advise on this would be helpful.
Hans Weilenmann
by Hans Weilenmann » Mon Nov 23, 2009 3:54 pm
Aaron,
I wrap the hackle into and over the tie-down point for body and rib material. Like this quick & dirty copy - full and detail:
How does it look to you?
skunkaroo
by skunkaroo » Mon Nov 23, 2009 5:05 pm
Nice. Nice marabou too--much better than the junk I can get locally.
What weight thread are you using? With the thinner thread I find the material steps down in a slope and the hackle wraps "slide" forward (for lack of a better term). I'll give it another crack here and post again.
Hans Weilenmann
by Hans Weilenmann » Mon Nov 23, 2009 5:07 pm
Aaron,
My staple thread, Benecchi 12/0, used here too.
skunkaroo
by skunkaroo » Mon Nov 23, 2009 6:41 pm
Hans,
I tied this prior to reading your reply and decided to use silk (chestnut in this case).
Full
Detail
While it's still not prefect (pesky marabou barbules), the results are better. I made a concerted effort to bring the material as far forward as possible (longer marabou would have helped), and to keep the binding wraps to a minimum. I also tied it on the Mustad 9672s which I normally use.
Needs a bit more, but much improved.
