by Roadkill » Sat Jan 18, 2020 12:40 pm
driftless
That is what I did for my home tying station...
IMGP9437 by
William Lovelace, on Flickr
I bought the large bobbins for some portable tying kits. The purple spool in the original photo is one of the bobbins from my Kimono tower.
ForumGhillie
I tied for about 20 years as you described without a bobbin and I am now too spoiled to go back, it is sooo easy to just let a bobbin hang. If I break my thread I grab it with one of these...
IMGP9986 by
Bobfly
by Bobfly » Sat Jan 18, 2020 1:28 pm
Just to consider downsizing to avoid bulky bobbins at the vice I shift thread off big spools onto small mini bobbins. These you can buy in dozen packs in a sewing shop and they are the bottom bobbin in a domestic sewing machine and you just use the machine's own bobbin filler system to fill the small bobbin from the main spool. Quick and easy and then you can make a big volume reduction. Very handy too for any mobile tying set up if travelling. Bottom mini bobbins are available in metal and plastic and I have two bobbins loaded with fine copper wire and a silver wire one, and find that their handling during tying gives good control.
by Ron Eagle Elk » Sat Jan 18, 2020 8:32 pm
Bobfly, I'm using the Wasatch Mini-Bobbins for silk thread. I borrow my wife's sewing machine to transfer silk to the smaller bobbins as well. I have about 20 of the mini-Bobbins, so I keep them loaded with silk colors I commonly use. I may have to try a couple for wire also.
by Roadkill » Thu Feb 20, 2020 11:31 am
A trip to a fabric/craft store and the local hardware store set me up to load sewing bobbins with Kimono and YLI silk for my expo tying box...
IMGP0028 by
a tapered metal pin to fit into the bobbins and a plumbing washer drilled to fit enabled me to spin up the silk with my variable speed drill...
IMGP0032 by
Roadkill's Pearsall's replacement silk selection ready for the Albany Expo
https://nwexpo.com/wp/
by letumgo » Thu Feb 20, 2020 12:38 pm
Nice!
Thanks for sharing Bill. I enjoy seeing your inventiveness and creative problem solving.
by letumgo » Fri Feb 21, 2020 1:51 am
John - Are you getting rigged up for an OPST line?
by redietz » Fri Feb 21, 2020 3:49 am
Roadkill wrote: ↑Thu Feb 20, 2020 11:31 am
A drill bit with masking tape wrapped around it is a less elegant, but cheaper and probably faster solution.
by Ron Eagle Elk » Fri Feb 21, 2020 7:52 am
ForumGhillie wrote: ↑Thu Feb 20, 2020 8:22 pm
Bill, that is cool. I could have used your setup to put the Lazar shooting line on my new reel last night. It would be a lot faster than a pencil and begging my wife to hold the pencil for a minute.
My wife held the pencil for two Hardy Ultralite 4000's for new backing, Lazer line and Commando head, only because one of them was hers.
If anyone runs across a sub for Pearsall's 6A, post it up please. Carl did an amazing job researching the color subs for every color I normally use, except 6A.
by joaniebo » Fri Feb 21, 2020 4:54 pm
Ron Eagle Elk wrote: ↑Fri Feb 21, 2020 7:52 am
Ron
I believe that YLI #216 should be close to Pearsall Hot Orange #19 and YLI #231 should be close to Pearsall #6a.
by Ron Eagle Elk » Fri Feb 21, 2020 8:28 pm
Thanks, Bob. I was looking at that YLI 231, but only on the computer. Appreciate the heads up.
REE
