Head Cement; I need a New Source
Re: Head Cement; I need a New Source
Thanks John.
Cellire is varnish and here is the gold standard of varnish.
If you use varnish throughout the tying process flies become bomb proof. This includes swiping your tying thread with varnish before applying dubbing. It is the easiest way to dub seal's fur.
- Varnish.jpg (57.33 KiB) Viewed 14488 times
Do you use a bodkin for this process?
Rumpf is great stuff.... cut with lacquer thinner
Shellac - thin with alcohol
Man O War is the best !!tworod wrote: Thu Feb 24, 2022 9:54 am Cellire is varnish and here is the gold standard of varnish.
- JohnMD1022
"One of those harmless misfits you see in fishing who do no appreciable damage to the world at large and in the end have only cost themselves the normal life that they never wanted anyway."
No Shortage of Good Days by John Gierach
Yes, just run the bodkin along the thread when dubbing. I use varnish throughout a fly using my bodkin to apply a touch at all critical steps.
I'm no chemist, but Cellire and Spar Varnish are as far as I can tell very different things. Man-o-War spar has a mineral spirits base; Cellire has toluene. Perhaps someone which a chemical engineering background can explain this with more clarity--and also outline the toxicity risks.
bb
- JohnMD1022
After looking around a bit, I found the Windsor Newton varnish is about $3 cheaper than at the art stores.
That Wapsi applicator looks neat, but not at the $9.49 Bass Pro Shop wants, or the $8.50 from Orvis.
Flymasters.com sells it for $1.99.
Any comments from a user?
- JohnMD1022
The varnish from Hobby Lobby.
