Leisenring Method of Dubbing a body (Tutorial / SBS)
Post by Soft-hackle » Sun Jun 13, 2010 9:25 am
Re: Leisenring Method of Dubbing a body
Post by narcodog » Sun Jun 13, 2010 11:07 am
I have tried that and JS has shown me but I am just not coordinated to do it. I slip a dubbing needle in the loop and the spin it. :oops:
Post by willowhead » Mon Oct 17, 2011 10:30 pm
Bob, you can buy the brushes pre-made nowdays. You just gotta hunt up where. Try google....... ;) .........or this. http://www.dougswisher.com/dubbing_brushes.htm 8-)
check out somma his WILD dubbings.......... :shock:
Re: Leisenring Method of Dubbing a body (Tutorial / SBS)
Post by letumgo » Mon Jan 02, 2012 1:21 pm
Here are a number of additional links which discuss various design of dubbing spinning blocks used to form Leisenring-style dubbed silk chenille bodies:
http://www.flymphforum.com/viewtopic.ph ... 0&start=10 (Discussion of Leisenring-style method)
http://www.flymphforum.com/viewtopic.ph ... ilit=block (Photos of Gunnar Johnsons' Gift from Pete Hidy - dubbing block)
http://www.flymphforum.com/viewtopic.ph ... ilit=block (Discussions of dubbing blends)
http://www.flymphforum.com/viewtopic.ph ... ock#p24638 (Nifty wooden block design for holding dubbing brushes)
http://www.flymphforum.com/viewtopic.ph ... ilit=block (Leisenring Method Revisited)
http://www.flymphforum.com/viewtopic.ph ... ilit=block ("I dubbed Leisenring fashion" - Discussion of alternate methods)
http://www.flymphforum.com/viewtopic.ph ... ilit=block ("Interesting Find" - discussion of early dubbing block)
http://www.flymphforum.com/viewtopic.ph ... ilit=block (Nelly B Pattern - Example Fly)
http://www.flymphforum.com/viewtopic.ph ... lock#p4237 (Buffalo Plaid Pattern - Example Fly)
http://www.flymphforum.com/viewtopic.ph ... ilit=block (Dark Hares Ear Spider - Example Fly)
