by daringduffer » Sun Nov 07, 2010 8:17 am
Take two of these
and two of these
Remove the heads of the pins and mount them in the pens. Magnetize one of the pins and use this pen to pick up the hook from the box when you are about to tie a fly. This is the easiest and quickest way I have found to do this. The other pin/pen is very handy to place that small drop of laquer needed on the head of the finished fly. I then clean the needle in a small sponge before putting the tool down...
If one bends the point of the pin it is easier to get just the right quantity of laquer. Trial and error needed - at least trial. You can skip the error altogether.
Is this allowed on the forum?
by Soft-hackle » Sun Nov 07, 2010 8:50 am
Hi dd,
Why not! If anyone has some tips for gadgets, tips, tricks, etc. They are always welcome.
by hankaye » Sun Nov 07, 2010 9:54 am
Howdy dd,
What is the first take 2 of these????? photo did not make the trip.
The beadhead straight pin did make it
by daringduffer » Sun Nov 07, 2010 11:14 am
hankaye wrote:Howdy dd,
Allright - I try another way:
If the image doesn't show up, just take any mechanical pencil that can take the pin...
I use 0,7mm.
kanutripr
by kanutripr » Sun Nov 07, 2010 11:32 am
Excellent tip!
I have a strange question. Does anyone have magnetic scissors? I picked up a pair of fine, pointed scissors at Bass Pro that were sans packaging that say COZIC stainless Japan on them. One day when I picked them up from the tying table there was a hook stuck to them. I thought it was just stuck to the point and gave them a little shake but, no, it appears they are magnetic. Both interesting and annoying. Since they came without packaging I have no idea if they are supposed to be like this or if it's some strange accident. Maybe I should have kept this secret, got a patent and made millions of dollars, huh?
Vicki
wayneb
by wayneb » Sun Nov 07, 2010 11:39 am
"Brilliant"
Thanks for sharing;
Wayneb
by daringduffer » Sun Nov 07, 2010 12:43 pm
Vicki,
I suppose your scissors - with or without purpose - have been in contact with something magnetic. I used a "fridge magnet" to magnetize my pin. If you only want to pick one hook up, you don't want too much magnetized steel - hence the small pin.
There you are - just make millions of dollars and donate some of it to the site...
PS Leisenring used a knife. I use a scalpel to make these delicate cuts of fibers - both thread and feathers. I get better control that way than with scissors. DS
kanutripr
by kanutripr » Sun Nov 07, 2010 1:45 pm
I do keep a razor blade that has one edge duct taped (to keep me from cutting myself) for really fine work but generally the small scissors are great because I can cut when I'm preparing the feather or use them like a scalpel when I am trimming the tips after wrapping or trimming off the thread when I've finished the whip. I find that when I'm tying I have a tendency to set things down and have to search to find them again so it's better if I don't have too many tools!
Vicki
kanutripr
by kanutripr » Sun Nov 07, 2010 4:01 pm
That's great Mike!
It'd be a lot harder to poke yourself in the eye too!
Vicki
CM_Stewart
by CM_Stewart » Sun Nov 07, 2010 8:25 pm
Couldn't follow the link. Got this message:
We have detected you are visiting this site through a proxy server.
We do not allow access to this site through open proxy servers
and request you visit these pages directly by typing the URL into your browser.
Thanks you
Even typing the URL directly into my browser results in the same message.
In any event, I've often wondered how many of the guys who never put down their scissors, in order to save what, 10 seconds per fly? still have both eyes.
Much too risky for me.
