Hopper legs
fflutterffly
Hopper legs
Post by fflutterffly » Mon Aug 22, 2011 10:36 pm
I've been sitting here for 20 min. trying to figure a way to tie the PH tail legs and my fingers have turned into toes. Suggestions please or a vid. demo please.
Re: Hopper legs
Post by hankaye » Mon Aug 22, 2011 11:31 pm
Fflutterffly, Howdy;
Just did a quick search over at flytyingforum;
http://www.flytyingforum.com/index.php? ... mMainBar=1
3rd. one down might help...
lykos33
Re: Hopper legs
Post by lykos33 » Tue Aug 23, 2011 12:40 am
small crochet needle or, I believe its called a nit picker. You find them at walMart in the sewing section. Looks like a small hook with a piece that flips back up once you hook the thread or in this case PT fiber...
Re: Hopper legs
Post by tie2fish » Tue Aug 23, 2011 7:23 am
I use tweezers to reach thru a loop and pull the "top" end back through. Experimenting will teach you how manipulate the knot location ...
skunkaroo
Re: Hopper legs
Post by skunkaroo » Tue Aug 23, 2011 12:31 pm
I use a very fine crochet hook, but you can use a simple bodkin needle as well. It just takes a little practice. You essentially make a loop with the fibres and then flick the tips through the loop. Not hard when you get the hang of it and it's great to do up a bunch while you're watching the tube.
Author Stream Time Blog
Re: Hopper legs
Post by Roadkill » Tue Aug 23, 2011 2:51 pm
A curved hemostat works well for me too!
kanutripr
Re: Hopper legs
Post by kanutripr » Sat Aug 27, 2011 11:06 am
Have you tried the little threading tool that comes in a sewing kit? I've never tied PT legs before but that seems like it should work. Maybe a small mono loop taped to a toothpick or pencil. Great, now I've got something else to add to the list of things to try. :roll: :lol:
Vicki
redsedge
Re: Hopper legs
Post by redsedge » Sat Aug 27, 2011 11:53 am
Go to Charlie Craven's site and look at the tutorial for Dave's Hopper. Charlie shows you how to use the nit-picker.
http://www.charliesflyboxinc.com/flybox ... rentID=147
fflutterffly
Re: Hopper legs
Post by fflutterffly » Sun Aug 28, 2011 8:37 am
Here is my method for tying hopper legs using Pheasant Tail:
#1 Pull off about 5 barbs after "combing" them to equal distance
#2 With thread I wrap the "stem" end of the barbs 3 times
#3 Pull tight and put 2 hitches on and cut ruff off end for a clean end to push through loop
#4 loop end over end, pull threaded end through hole, pull tight while sliding loop down towards barb ends
#5 Dab a little Sally Hansen on knot for strength
fflutterffly
Re: Hopper legs
Post by fflutterffly » Mon Aug 29, 2011 4:52 pm
OMG he does the legs on the feather! I've got to get on of those tools and try that method.
