Bird's Nests color combos
Post by Old Hat » Tue Mar 05, 2019 3:52 pm
Some of you asked for samples of the different colors I use for my Bird's Nest. I have always tied my nests for mayflies. I tie them a little thin and with sparser wood duck than Cal's original. See Doug's example for a better tie of the original. Still messy though. I also tie some with small beadheads either copper or nickel.
The original is on the left. The basic mix is 50% Austrailian Opposum, 40% Hare's mask and 10% natural seal. The others are variations.
The second is a yellow one. Use the Australian opossum, lighter hare and yellow seal for this one.
The next one is the Spectral Bird's Nest. The 10% seal is a mix of the primary and secondary colors of seal.
The last one on the right is my dark nest. I use Australian opossum, hare dyed dun and black seal.
reduxBirds Nest 4.jpg (165.04 KiB) Viewed 6641 times
reduxSpectral Birds Nest Dubbing.jpg (198.56 KiB) Viewed 6641 times
Re: Bird's Nests color combos
Post by Roadkill » Tue Mar 05, 2019 3:57 pm
8-)
But have you created one for the Salt yet? ;) :)
Post by Old Hat » Tue Mar 05, 2019 4:22 pm
Roadkill wrote: Tue Mar 05, 2019 3:57 pm 8-)
Pretty sure a version could be made into a shrimp pattern fairly easily.
Post by Roadkill » Tue Mar 05, 2019 5:09 pm
The Spectral blend looks like a good sub for the tan UV2 scud/shrimp dubbing that I bought last week! ;)
Post by Theroe » Tue Mar 05, 2019 5:34 pm
Tell you what, Carl - that has to be one of the nicest spectral blends I have ever seen.....LIKE!!
Post by Old Hat » Tue Mar 05, 2019 5:51 pm
Dana - Since I first made a blend years ago I've been hooked. I bought into the theory behind spectral blends from the get go.
Post by letumgo » Tue Mar 05, 2019 6:08 pm
Marvelous series of flies. This colors would cover a very wide range of insects.
It is no wonder this pattern has become such a confidence pattern for you.
I need several rows of these in my fly box, come spring.
BTW I love the idea of a salty shrimp version. Great suggestion.
Post by Mike62 » Tue Mar 05, 2019 7:54 pm
Thank you for posting this, Carl. I love this pattern. I've turned into a dubbing junkie and this just strings the addiction along.
Post by ronr » Wed Mar 06, 2019 11:25 am
Carl.. I'm now glued to my desk tying a set of these bird's nests... I'm absolutely certain that when the redfish start rooting those juvenile shrimp off the bottom in the shallow flats, that your birds nest will work... maybe with some bead chain eyes added.... I know.. wont be a certifiable flymph...but I think will fool a redfish..or a spec....or a flounder ....
Terrestrial12
Post by Terrestrial12 » Thu Apr 14, 2022 10:04 am
Great work! I actually have a lot or Cal's birds nest dubbing from his personal collection as well as some of his dyed flank and various other dubbing blends if anyone would like to see photos for reference.
