The Dark Needle
The Dark Needle
Post by upstatetrout » Thu Mar 19, 2020 1:05 pm
Hook. Daiichi 1480 size 16.
Silk. Pearsalls Gossamer sherry spinner #6b.
Head. Magpie Herl.
Hackle. Brownish Starling wing joint feather.
Body. Sherry spinner
Re: The Dark Needle
Post by Ron Eagle Elk » Thu Mar 19, 2020 11:05 pm
Stunning! Beautiful wee head of magpie herl.
Re: The Dark Needle
Post by redietz » Fri Mar 20, 2020 1:38 am
Looks great!
Re: The Dark Needle
Post by daringduffer » Fri Mar 20, 2020 7:43 am
Did you tie in the herl first?
Re: The Dark Needle
Post by upstatetrout » Fri Mar 20, 2020 8:47 am
Yes the Herl is tied in first then the Hackle is tied in and wrapped back towards the bend then the body and finally whip finished behind the Hackle. Not the easiest method but there should not be any head on the fly other than the Herl.
Re: The Dark Needle
Post by Theroe » Fri Mar 20, 2020 9:38 am
upstatetrout wrote: Thu Mar 19, 2020 1:05 pm Hook. Daiichi 1480 size 16.
Nice Tom - One of my favorites. I use that fly quite a bit on the Beaverkill.
PhilA
Re: The Dark Needle
Post by PhilA » Fri Mar 20, 2020 1:02 pm
Those herl-headed wingless wets are a bear to tie neatly. Well done. --Phil
Re: The Dark Needle
Post by daringduffer » Fri Mar 20, 2020 2:04 pm
upstatetrout wrote: Fri Mar 20, 2020 8:47 am Yes the Herl is tied in first then the Hackle is tied in and wrapped back towards the bend then the body and finally whip finished behind the Hackle. Not the easiest method but there should not be any head on the fly other than the Herl.
That's the way other clever tiers tie them too. Nice hackle!
Re: The Dark Needle
Post by DOUGSDEN » Fri Mar 27, 2020 9:06 pm
Tom,
Your pattern above is quite stunning! I like the magpie hurl at the head! Very buggy looking pattern overall! For some strange reason (and this is assuming my little speckled darlings are basically pigs at heart) this pattern has not been well received! I have fished it all season long. It just doesn't seem to garner much interest! I cannot explain this! Any thoughts on why?
