Double Hook Greenwells.
Post by Mataura mayfly » Fri Feb 08, 2013 5:00 pm
Recently my much better half Kim had to have a surgical procedure. Whilst waiting on pre-op exams on Monday last week and whilst Kim was in theatre and recovery on Tuesday it gave me a chance to catch up on a little reading.
Mr Ron Eagle Elk sent me over a wonderful book, "The Upstream Wet Fly" by Terry Lawton, which is a wonderful read. Many thanks Ron. :D
Within the pages of this book I discovered a "new" (to me) method of adding weight to a pattern without using beads or lead wraps.
Tie the pattern on two hook laying side by side, so the body of the fly wraps around two shanks and you get a fly with a double weight hook- without using a heavier or longer hook.
The idea intrigued me, could not see how to do it with eyed hooks- so used a couple of cheap bait style hooks and cut the eyes off. I then snelled on a section of tipped to one hook in the vice, removed that one and snelled the other end of the tippet section to the second hook. Folding the short tippet section as a hinge formed the eye and allowed the two hooks to come together as one to commence tying. Kind of like a small salmon double..... but the bends of the hook can be moved to open or close the angle the two hooks form.
Anyhow, here is my take on the Greenwells double hook.
Re: Double Hook Greenwells.
Post by Ron Eagle Elk » Fri Feb 08, 2013 6:17 pm
Jeff,
Very cool. I like the look and the idea of it. If a fish takes it will the entire contraption come apart? Just wondering about that. Maybe super glue the two shanks in place, but then it wouldn't have the ability to be open or closed. Hmmmmm.
Glad your enjoying the book.
Post by Mataura mayfly » Fri Feb 08, 2013 6:30 pm
Ron, haven't fished it yet..... so I do not know, but- seeing as how odds are both barbs will be in the fishes mouth and tesion in the opposite direction through your line and the "eye" is attached to both shanks it should not pull apart.
If by chance only one barb imbeds in a fishy jaw then it might be a different story. One of the shanks may pull back out of line with the other. Should be able to be pushed back into line if the seperation it not too pronounced.
I have put the effort required into the "too hard" basket for regular tying, more of a "try and see" novelty tie. Though I may fish this one..... just to see what happens.
Post by letumgo » Fri Feb 08, 2013 11:41 pm
Fascinating. I've never heard of such a thing. You did an amazing job.
Post by wsbailey » Fri Feb 08, 2013 11:45 pm
Skues recommended this procedure to get a heavier wet fly hook:http://archive.org/stream/minortacticso ... 7/mode/1up. Bill
Post by Kelly L. » Sat Feb 09, 2013 5:11 pm
Glad to hear you had something to keep you busy. I hope Kim is doing well now!
