Glass Spider
Hook: Kamasan B175 #14
Thread: Benecchi 12/0, black
Hackle: Whiting hen, badger
Abdomen: Krystal flash, pale pink - flat
Rib: Krystal flash, pale pink - corded
Thorax: Ostrich, black - twisted around tying thread
Are you holding the crystal flash in you fingers when you cord it or in a hackle pliers?Hans Weilenmann wrote:
One piece. No trick. Simply wrap touching turns to bend, keep tension, and cord the ribbon - then spiral back towards eye.
EZ Pliers - I doubt one could control the twist required, and maintain the needed tension, doing it with fingers alone. While standard hackle pliers would work, the tube on the EZ Pliers makes the twisting fast and easy, as well as controlled.Are you holding the crystal flash in you fingers when you cord it or in a hackle pliers?
